While cruising at speed apparently someone hit the windlass switch by accident. I had replaced the original momentary-ON, OFF, momentary-ON switch with one that works ON, OFF, momentary-ON so I don't need to keep my finger on the button while dropping anchor and can use both hands for steering which I need to do in crowded places under heavy wind. With the switch turned on and anchor/chain being dropped we did not immediately realize it and by the time we realized it it was too late! The engine came to a sudden stop with a terrible sound. I needed to call for assistance and were able to unwinded the chain and pull it back in. Chain and anchor and the windlass are working OK. So is the engine. However the propellers are toast. Even worse, the props don't turn when I put it in gear. I had to be towed a long distance to shore and then the boat was lifted up on a truck for a long journey home. Back home my mechanic removed the drive and observed the transmission gears are OK but some parts/linkages need to be replaced. The really bad news is the engine coupling is broken. He thinks this will require the engine to be lifted out.
I have the QSD 4.2L Mercury engine in a Bayliner 285. Does anyone know if the coupling can be replaced without removing the engine?
Lesson learned: always have a chain lock engaged to prevent such a situation.
Any advice will be greatly appreciated.
Safe cruising
Safe cruising
