How to change the fuel tank on a 1981 25(39) Saratoga Sunbridge ?-gctid823388
    I developed a leak in the bottom of my fuel tank and am thinking the only way to remove it is to cut a large hole in the mid berth floor, or to pull the motor and cut the rear brace and hope it slides out with the semi-dense foam between it and the mid-berth floor, does anyone have a procedure or ideas, thanks for your help Bruno7087
    Welcome to the forum!
    You got it right. Pull engine or cut holes.Slightly different boat, but worth a read.
    Joel
    1987 3818 Hino 175
    "Knotty Girl"
    Prince Rupert B.C.
      Thanks canoel , this is going to be a winter project and will post some pics when all done or run into a problem I cant figure out
