2005 bravo 2 outdrive-gctid823270
  • 2005 bravo 2 outdrive-gctid823270
    Hey everybody I hope this summer was good for you. Just curious if anybody knows if the 2005 MerCruiser bravo 2 outdrives still have the grease fittings on the u joint ? Not sure if I'm saying the correct word it's when you pull the outdrive off it's the Yoke that still connected to the outdrive and that Universal U-joint that flips and flops that yoke any different way I know my 2000 Bravo Two had grease fittings on it just curious if they stop putting grease fittings on them or are they still on there
    I guess nobody knows
      There are grease fittings on my 1997. I don't think those went greaseless later like the gimbal bearing did. Should be the same as the B3 though. Lots of 2005s on here with those.
      Bryan
      1997 2858 7.4 B2
      1992 Hewescraft
      Puyallup, WA
        Thanks buddy I know my 2000 Bravo 2 had the grease fittings on the U-joint Universal not sure if the 2005 does
          Not 100% but I'd think they all have zerks, it's a serviceable part.
            Ok tks
              Around 2006 Merc went with Perma lube gimbal bearing & universal joint crosses,
              I've seen a few 2006 B3s with non-greaseable Ujoint if I remember right
                ok thank you
