2556 Command Bridge rocker switch labels need help please-gctid823242
    1988 2556 - does anyone have the diagram or a picture of the correct labels for the rocker switches on the bridge? I am rewiring and labeling everything. So far I have the Nav lights 3 way, Instrument Panel lights, Stern-drive Trim, Horn, Bilge Blower, Bilge Pump, Key for maceration pump, There are two more switches and I have 3 more blue wires. Blue seams to be lighting. Could this be the courtesy lights by the step? Not sure what the second switch would be for. Thanks JR
    Mines a 93 so it'll be a bit different. Probably courtesy lights and the other may be accessory. Here's what mine looks like if it'll help.
      I'm looking at the pics I have of the 2556s I looked at while shopping. The '89 and '91 models I saw had flip switches on the flybridge, not rocker switches. It's hard to make out the lettering (and the '89 is partially covered by a tree branch) but here they are FWIW.
      https://photos.app.goo.gl/YL7mr7Nmiy8iZBYh1
      https://photos.app.goo.gl/XhCrcZ8OiSdN1rEd2
      If the flip switches are factory original on the '88, then your rocker switches are probably an upgrade added by a previous owner. You're going to have to rely on wire colors to figure out what activates what. The last page of the manual should have a wiring diagram with wire colors.
      http://bayliner.com/wp-content/uploa...era-Trophy.pdf
        here are the panels from my '88... the first one is the upper station, the second one is the lower station..
        NU LIBERTE'
        Salem, OR
        5.7 OMC Cobra - 15.5x11 prop
        N2K equipped throughout..
          Thank you!!!!
