Full closed cooling or no?-gctid823188
Mike, It looks to have Mercruisers SS exhaust elbows but I can't see if there's a raw water hose feeding them or not. If they're capped off then she's part closed.
Post a pic of the exhaust: manifold, spacer, elbow and the hose connections to them.
Dave in the first picture there is a hose coming off the HE that splits and goes to the elbows which should be raw water. In the last picture there are two hoses coming off the t-stat and two on the backside of the HE which appears to be closed cooling for the exhaust manifolds.
ive been messing about with boats for many years, and I suppose its time for someone to enlighten me about the "partial" closed loop cooling system. I have never heard of such a thing or how it would work. maybe it means a closed loop cooling system with dry exhaust?...
you have a heat exchanger, so in my opinion you have a closed loop cooling system.... you should see fresh water and coolant under the cap of the heat exchanger that flows around the outside the tubes of the heat exchanger, and then out in a loop thru the motor, circulated by the engine water pump. at the same time, sea water is picked up by the impeller in the lower unit and sent to the heat exchanger where it passes thru the tubes inside the heat exchanger, and then dumped into the water jacketed exhaust manifolds to cool them as both the exhaust gases and the water flow up and over the riser elbows where they now mix together and exit thru the outdrive...
NU LIBERTE'
Salem, OR
5.7 OMC Cobra - 15.5x11 prop
N2K equipped throughout..
A "Partial or half" closed cooling system circulates coolant through the engine only and the exhaust manifold and elbow are raw water cooled.
2013 Boston Whaler 130 SS
Isla Verde, PR
If you have trouble following the hoses the easiest way to see is crack open a plug on the manifold ( not the riser) and see what comes out. If its antifreeze it's full closed. Of course that's assuming you have antifreeze in the block.
1989 Avanti 3450 Sunbridge
twin 454's
MV Mar-Y-Sol
Twin chevy 350's inboard
Ben- Jamin
spokane Washington
"Norton Rider" post=823211 wrote:
A half system runs raw water through the exhaust manifolds up to the risers and overboard. A full system runs coolant through the manifolds. The risers still get raw water and this goes overboard. The advantage of a full system is that manifolds last much longer.
NU LIBERTE'
Salem, OR
I will get more pics tonight. If I recall one of the tubes off the risers run to the heat exchanger. Which is deceptive because that doesnt mean its coolant, that could still be raw water from the outer jacket, routed to exit through the exhaust.
The raw water pump is belt driven, these are bravo 2's.
Yes its insane how tight it is, not looking forward to doing anything down there, am pulling engines for rebuild this winter.
Difference between half and full is as stated, exhaust manis are still raw water cooled. What confuses me is in a full, there is a plate that blocks the jackets from the risers.
Unless my terminology on what parts what on an exhaust system is wrong, why do they sell full aluminum kits if the riser still gets raw water through it?
1993 formula pc 31 twin 454 bravo 2
1989 2655 cierra 5.7 omc cobra
2014 "searay" tandom trailer
Anchor bay clinton river
Michigan
As well this boat has strainers in the bilge for the raw water pick up. Idk if this is factory or not.
If I understand correctly: Ive read of people modding this to avoid sucking up muck the drives churn up. From here they would cutt the raw water tube outside in the transom assembly for the drives and do a block off from the belt driven pump that would feed the drives? Idk that system confuses me. And honestly these strainers have been a pain, everytime i leave my slip in the canal they get clogged. Last time i didnt wven make it out of the river and had to go diving to clear the scuppers. I would way rather lift the drives and lay on the playform and remove debris. Wish there was some back flush valves for the strainers
Michigan
