Hey all,
I'm putting a new stereo in my 97 Bayliner Capri 2050 LS. It has a factory 6 pin plug in the port side console which had a harness plugged into it (which I'm assuming is the harness from the stereo that came in it from the factory) that the previous owner spliced the harness for the head unit that he put in that quit working on me. Anyway, one of the wires pulled out of the connection and I'm needing something that I can splice into that will plug into the harness that's already installed in the boat. Is there any place I can buy a plug and play harness, or even that I could find an old harness off of whatever came in the boat factory that I could splice into that would plug in? I'm going to take the harness I've got to work with me where I have the right tools and see if I can't pick the connection and repair it but just in case I can't, I'm wondering if I've got anymore options
I would just cut the connection on the 6 pin and wire it directly into the boat that way, but it's so far up in the console, you can't get up in there to do much of anything. Plus, my big hands don't help matters much either.
Just in case all the above sounds confusing, I'll try and post pics here in a minute of what I've got.
Any advice or tips would be greatly appreciated! Thanks in advance!
