Hi Folks,
I have a question about the volt meter on the dash of my Bayliner Ciera. The guage reads maybe ~10v but the batteries are recieving a full charge. I installed an isolator in line but prior to that the guage read ~13v. I tested the charging system with a meter and its charging perfectly and the batteries are charging properly.
The question is where does the meter read voltage from and will the isolator typically cause this kind of behavior? Or do I just have a bad guage? I dont think its the guage because if I take the isolator out and start the boat, the guage reads ~13v again.
