what is the best way to separate the engine circuit from the (34)house(34) circuits?-gctid822942
    I want to have the start battery separate from the house circuits so that we dont end up "dead" on the hook somewhere.
    my 2556 is an '88 and I have the wiring diagrams but I cant seem to work out the details of what needs to happen to separate the two systems from one another.
    I dont even know where they are joined at so I dont know where to look. its not really a complicated or large electrical system so I dont think it should be too hard to do, but where to start?
    I already have in place a blue sea dual circuit plus disconnect switch, with both batts connected properly to it, with one battery connected to the engine only, and the other battery connected to what I believe to be the origination of the house circuit. but the batteries still arent isolated from one another and im not sure where they are combined at, or what circuit to trace to find the link.
    is it possible that the batt +/- goes to the fuse panel at the helm, and that the engine and all house circuits originate from under the helm? if so, do I need to run another hot wire to the helm from my dedicated house battery?... the grounds are, and will be, all common so its not a concern.
    im absolutely certain this has been done many times, to all types of boats,. has anyone here done this to their boat?, and if so, what is the easiest way, or the proper way to do it? thanks
    NU LIBERTE'
    Salem, OR
    5.7 OMC Cobra - 15.5x11 prop
    N2K equipped throughout..
    I isolated my reserve (not "start") battery with the ACR
    as explained in this post. You use the house for
    everything and if (and only if) it fails, you switch over
    to the reserve battery and go on your way.
    https://forums.sailboatowners.com/in...usings.137615/
    1994 2859 in Tacoma, WA
    7.4 Mercruiser
    Still learning about other systems
    and specs.
      We do not see this ( typically ) until we get up into 34 feet and above. In my opinion, and as per your thread title....... there's absolutely no need to do this on your size boat!
      This is been discussed a number of times here on the BOC forums .
        I have been using this type of setup for many years, i really like the ACR system in combination with a correct circuit barker from Blue Sea. Alternator always charging starter battery( only used for starter) and hose bank charged through automatic voltage sensing relay. Not very expensive solution either. On my 2556 have been planning to add a third bank but have not yet figured out best way to connect that one, maybe another ACR relay....
        Bayliner 2556 1990 project
          The house and start banks connect at the MBSS.
          I'm with Rick on the Keep It Simple idea, no need to rewrite stuff just manage your MBSS so your start battery is never being drawn upon until you need it to start the boat.
            I do know exactly what you are talking about and would like to achieve the same thing on my boat.
            I also went with the Blue Sea system (switch & ACR) and thought I had the house side isolated from the starter side but it turns out that everything was still coming off the starter battery and the house batteries were powering nothing.
            I've got a couple different wiring diagrams but the one that looks best suited for my boat shows the helm panel coming off a wire harness that originates at the engine.
            Look for a red-purple wire (and a black ground wire) within that main harness.
            I have yet to do so myself but that's the game plan. (or I may just go back to the 1/both/2 switch and keep an eye on where I have it selected
            Wet'ever
            1989 Avanti 2955
            460 Cobra
              Yes, cabin wiring harness power is received from its connection to the the engines wiring harness. The engines wiring harness receives its power from whatever battery bank is selected at the MBSS. If your on the hook and MBSS is selected to #2 (house bank) your #1 bank (start) is not being drawn on and will be good to go if your house bank won't start your boat. Simply switch the MBSS to #1 and hit the key.
                and this is exactly what im trying to do... as it is now, both batteries are being drawn from... and yes, I can disconnect one and leave it out of any of the circuits completely, but the idea is to have both large batteries in service to supply my house needs, and a smaller start battery that is only for starting and not being drawn from for any other purpose... I know there are pros and cons to it, and as rick said, "we dont typically see this on boats until around 34' and above".... what does length have to do with it?, other than that is the length where the manufactures feel its worthy of doing... in my opinion, the need is more dictated by how the boat is outfitted and used, not by the length of it.
                .... but if the house circuit and the engine circuits come together at the MBSS, as you say, then it should be an easy separation... I will look there. thank you..
                NU LIBERTE'
                Salem, OR
                  as I look deeper, I think the answer is to run another 10awg hot wire (or larger as the house load demands), to the helm from the battery that has been prepared as the house batt... then add another fuse panel there at the helm. at that point, all the house circuits can be placed on one fuse panel, while the engine components remain on the existing panel..
                  if the dual circuit plus switch is in place with the acr connected, its then only a matter of determining which battery is the running the house, and which one is running the engine...
                  the batteries themselves are connected at the MBSS, but by replacing the common MBSS with a dual circuit plus switch, the batteries have been placed on separate circuits, with only the common hot wire running to the helm keeping ALL the circuits joined....
                  NU LIBERTE'
                  Salem, OR
                    As far as battery banks go: This is how your 2556 would have been set up from OEM. Both battery banks positive cables will connect to post 1 & 2 at the MBSS, The common post of the MBSS will deliver 12volt power to the starter lug via whichever bank has been selected. The starter lug is where the engine harness/hull harness recieves it's 12 volt power.
                    The wiring diagram also shows the onboard battery charger connections being made at posts 1 & 2 of the MBSS, this keeps from having multiple wiring connections at the battery posts. An auxilerary fuse panel is also shown connected to the MBSS, a good thing to do when adding extras like wash down pump, electric down riggers, fish finders ect.
                      Hi everyone been away for awhile I see this aged separating batteries theatd is up again. I have seperated mine I highly recommend but it ment rewiring whole boat which I found to have merit just upgrading once you see how much is run off the purple wire over the years it's amazing how many toys you can ad to a boat that require power. I have ARC system left the motor harnesses running gauges trim etc but removed everything else to new circuit. I have a single start batt with 2 house batts. If you chose to do it go the whole way Google is your friend learn what your amp draw will be with everything on add a bit for new toys that come on the market then half it as you don't won't to drain your house bank below 50% the original system works but I might park in a bay for a night or 2 so I went with separate banks.
                        Like said...... until we get up into 34 footers and above, we will not see the house loads separated from the engine loads.
                        Let the engine harness and hull harness interface remain as is.
                        Take another look at my schematic in post # 10.
                        Look at how the MBSS directs 12 vdc battery power by way of which batt bank is selected at the time.
                        Switch your MBSS to #1 SLBB and start your engine. (SLBB = start load batt bank)
                        While the engine is warming up, several things occur:
                        ...... your instrument panel, engine's starter motor, ignition system and all engine data devices will operate from #1
                        ..... the Amp Hours removed from the starter motor load are now being replenished.
                        .... all 12 vdc on board demands are now powered via the MBSS "Common" connection.
                        Now switch to the #2 HLBB and go for an outing. (HLBB = house load batt bank)
                        ...... your instrument panel, engine's starter motor, ignition system and all engine data devices will operate from #2
                        ..... #2 will be now be receiving the alternator charge rate.
                        ..... #1 batt bank will now be IN RESERVE!
                        Through the use of some great BlueSea products, this can become more automated.
                        But again....... in my opinion there is no need to separate House loads from Engine loads.
                          That's pretty much what I did, but rather than swapping to a dual circuit switch, I simply added a SBSS beside the MBSS. I now have completely separate systems where I never have to mess with the MBSS, especially when I'm out fishing for the day using electric downriggers. I've sent you a PM.
                          MMSI: 367637220
                          HAM: KE7TTR
                          TDI tech diver
                          Kevin
                            Is my battery selector switch "make before break" or
                            "break before make"?
                            I have a 1994 2859.
                            7.4 Mercruiser
                            and specs.
                              You would need to go back in time quite a few years to find an MBSS that was not "make-before-break"!
