Ok so i have a capri 2052 with deck rot. I bought the boat cheap like $250 cheap with trailer and both titles. I've started ripping up the rot and have questions. I've searched and found similar posts but I feel like I'm not finding answers I need. The boat has sat for a few years with leaves in it I'm assuming caused the rot. The hull and transom feel and sound solid. What I'm wanting to do with this is make it safe and get some use maybe a season or two and maybe upgrade it to a bigger boat with bigger cabin. So my questions are should i remove the seat bases or does the floor decking meet the bases outer edge? Also when I remove the wet foam should I replace it with more foam? Any suggestions are greatly appreciated.
The boat
after pulling carpet
after some cutting and vacuuming
I starting digging into the foam and its wet
The boat
