I apologize in advance for having to ask what should be a basic question. I've set timing in cars before they had computers, so that's my reference knowledge. (Connect timing light, Loosen the distributor, rotate based on markings down on the crankshaft flywheel etc)
I would like to check and adjust if necessary the timing for my 2006 Mercruiser 5.0L MPI engine. I have older Mercruiser service manuals and they seem to conflict.
Service manual #31 which includes the 5.0L MPI engine, circa Oct 2001, has no procedure listed for setting timing.
Service Manual #24, which also covers the 5.0L MPI/EFI engine but is older (circa 1999), has the procedure copied below.
So my first question is: is the older procedure correct for my engine? Or is there no need to adjust timing on newer engines? If the procedure is right, why do I need to connect a "Scan Tool" to the engine. Is this to disable the computer so that it doesn't try to compensate for rotations of the distributor? I had heard there might be a lead somewhere that has to be connected to ground to disable the computer, but this is not mentioned.
Thanks in advance for any insights!
Tom
EFI / MPI Models
1. Connect timing light to number 1 spark plug wire.
2. Start engine and run at 1300 rpm until it reaches normal operating temperature.
3. Stop engine and connect the scan tool or timing tool to the DLC connector on the EFI/ MPI wiring harness.
4. Start engine, allow rpm to stabilize.
NOTE: MEFI-1 models only, manually adjust remote control throttle lever to get 1200 engine rpm.
NOTE: MEFI-2 and MEFI-3 models only, ECM will automatically adjust engine rpm to approximately 1200 rpm when put in the service mode on a scan tool or when using the timing tool.
5. Check ignition timing. If incorrect, rotate the distributor until timing is correct. Torque clamping screw to 18 lb-ft (25 Nm).
6. Recheck ignition timing.
7. Disconnect scan tool or timing tool from DLC connector.
8. If required, return remote control throttle lever to idle position and shut off engine.
9. Restart engine, increase rpm to 1300 then return to idle position slowly. Ensure that engine returns to idle rpm. Readjust throttle cable, if required.
10. Shut engine off.
Tom
EFI / MPI Models
