throttle-gctid399378
    Anybody had this problem. In my 2000 1750 I go to put it in gear(on trailer) and the motor stalls. Its not the interrupt switch. Its like the throttle cable is not advancing to give any gas. When is the throttle cable suppose to move when you start pushing on control lever?
    I have a simular problem but mine is when i try to push the revs off idle after going into gear, it bogs down and stalls.
    No problem once is is warm.
    You might need to increase the idle a little.
    Does is do it in forward as well?
      Both forward and reverse
