After wrecking three shaft brushes by catching them on my clothes getting to the outboard side of the stbd engine, is there any reason the brush can't be mounted so it is on the bottom side of the shaft? Gravity has some advantage but it's spring loaded. Just thinking.
Shaft brush-gctid822729
A marine mechanic told me once that if you do not clean the contact surface of the brush frequently it will not work. Just thought I'd pass this along since upon learning this a friend of mine realized that he had never cleaned his.
1990 3288 twin 150 Hinos
previous: 1964 28' Owens express cruiser, v8 crusader
