I'm hoping someone may be able to provide some advice about a problem I'm having (I tried to attach pictures but couldn't get the files to upload)
I have a 2006 Bayliner Deckboat; in the floor compartment (where you keep the skis) the gelcoat cracked and allowed water to penetrate the underlying wood. My plan was simply to remove the affected gelcoat, sand, apply a new layer of fiberglass and a new layer of gelcoat and get back on the water. My concern, however, arises from the fact that moisture continues to appear despite the boat having been out of the water for 3-ish weeks.
Also...when I removed the gelcoat it appears there are several intentionally placed one-inch diameter holes in the wood containing some type of material (I can't tell if it's fiberglass cloth or something else). I have no idea why these holes are there, but the fact they're soaked makes me concerned.
Questions.....1) given these indications...should I be concerned about moisture being trapped underneath the compartment floor? If so...what can be done about it?
2) what purpose do these holes serve? What role do they/should they play in the repair process?
Thanks any and all who might be able to provide some wisdom. DT
