Long or small block, 350-gctid822476
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
KevinTags: None
Kevin, you have a small block Chevy 350ci as you listed,
Long block is an automotive term for an engine sub-assembly that consists of the assembled block, crankshaft, cylinder head, camshaft (usually), and valve train. A long block does not include fuel system, electrical, intake, and exhaust components, as well as other components.
Kevin, although it is not necessarily an automotive term exclusively, Joon is correct .
An automotive or marine long block would be an assembled cylinder block with installed cylinder heads.
This would typically include crankshaft, rods, pistons/rings, camshaft, camshaft followers, timing chain & sprockets, cylinder heads with complete valve train, etc. ............. minus the tin-wear (oil pan & valve covers).
Some will include the front timing chain cover and harmonic balancer...... some will not!
A short block would be an assembled cylinder block only....... minus the tin-wear.
Some builders are not including the camshaft, camshaft followers and timing chain/sprockets today..... so use caution and ask questions.
As for which is better...... there is no correct answer. It would depend on what the need is!
My thought, wasn't asked just gonna throw it out there.
A person buy's a complete engine from fuel delivery to pan, and coupler complete drop in engine, from say MM.
Something goes wrong, and believe me it happens alot, something goes.
MM will cover it, with the warranty, will Joe blow engine re-builder down the block cover his engine?
Buy a long block install all your old stuff something goes wrong, they have a out, it was your old elbow etc that went.
Buy a short block install your old cam or a " hot " cam or say a standard one bought somewhere else, will the manufacturer of the engine cover it ?
What does a boater really want ?
To go boating, and not have the boat on the hard after spending alot, to refit.
Me now today, i am searching for a boat that only needs a engine or outboard. really 2 engines.
Leaning towards twin outboards .
Thanks for your posts. I'm taking myself to school on the mechanical, fighting my belief that I will never understand this, so anything you can assist me with is extremely appreciated. TBH, I didn't quite understand Joon's post after reading green650's post. I thought long and short were actually different sizes of block.
So, if I understand this, a long and short block have the exact same block, but the long comes complete with everything except covers, and short comes as just the block so you can add whatever you want to it?
Mount Vernon Marine completely rebuilt this engine before I got it. Their machine shop donated a 5.7L block after the PO literally shattered the original 5.0L, to which they bolted the remaining working parts from the 5.0L. Reading this, ....
....which would mine be? Or at this point, does it really matter since it was pretty much pieced together?
And the comment, 'dropped in' means they rebuilt this on their bench, then put it in the boat? Why might this matter?
Also, there was some confusion when I purchased the boat that it may not be a Vortec. Reading this, would the choke comment verify that it is, indeed, a Vortec?
So, if it is a Vortec, and considering it now has oversize pistons, what might you guess the HP is? A best guess is fine.
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
Yes, Vortec top end. .040 over w roller camshaft, gotta be somewhere around 300 I'd think. You still running points in the distributor?
If I ever have to switch out the Cobra, I'm going with the VP DP-S, and I'll have him install the Mallory electronic ignition.
Tell me, at that point, how feasible is it to change it to fuel injection?
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
Better off buying a new vortec with new carb and electric fuel pump from Michigan motors for under 5 boat bucks. I did that for my 2252 and it started quickly and ran like a raped ape. Still had to pump the throttle some times.
Now as for my 2859 with MPI, that thing fired up in a couple seconds every time! No throttle pumping. But, it's simply not worth converting from carb to fuel injection.
Sadly, I put my 2859 on the ferry to Alaska yesterday and now I am boatless other than my 10' dinghy.
Esteban
Huntington Beach, California
2018 Element 16
"green650" post=822579 wrote:
....a raped ape.
I read on another thread about racing mechanics going back to carbs. I have no issue with either, just thought injection was more fuel efficient, ...but that is simply cost prohibitive. Not sure there would be any other gain. I would like to replace the Cobra someday, which will allow to change the ignition. Otherwise, I've very happy with what I have. And 300hp? I've VERY happy with what I have!!
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
