Well this is one of those questions that I am pretty sure can't be helped online and I just need tonpainfully dig around. But I'll throw it out there for any tips on tackling.
First off. Why is when I try to do something I break something. Happens all the time
So I have what I am pretty sure is a YL420 zodiac
There is a bilge pump under the rear seat. It didn't seem to be working so I took all the crap out there and messed around a bit. Trying to see if had power etc.
There is also a small access hatch under the wheelnin the console. There is wiring for the dash switches etc there.
I had a rummage around in there too.
And voila my Nav lights no lover come on.
So I am presuming I disturbed a connection somewhere or something was old and corroded and broke.
Looking for any tips on how best to trace the problem. I ain't that good with Electrical's
There is a 3 panel switch on the dash. A 3 fuse block from it in the console and then a bunch of wires for sounder speedo etc.
I checked fuses and checked what looks like 2 master fuses under the rear seat. All look good.
Where would you start on troubleshooting? Access is a pain.
I was hoping someone might have the same tender and have had a similar problem?
Final question there are 3 dash switches. I know the first is the nav light. Any idea what the other 2 should be for?
Stretching I know
Stretching I know
