Anyone know how to reset the (34)Accessory Circuit Master Breaker(34)?-gctid821885
One of your new best tools is going to be a multi meter. Take the cover off of the breaker and check to see if you have power on both sides of the breaker. Red to the breaker, black to ground, D.C. Setting.
You can also use the meter to check the switches that aren't working that may or may not be fed off that master.
