Backrest Seat clips for Command Bridge-gctid821846
    Does anyone know where I could buy this clip ? Its original to my boat and holds the backrest up on the commaned bridge to the fiberglass. Its on the starbird side and the backrest is L shaped. One clip was accientlaly bent and the other was broken when someone was working on my boat. Now the backrest is somewhat loose. Any help would be appreciated, as my screename says its 1996 3388 Bayliner. Not a super technical piece but it fits into the adjacent piece on the back of the cushion.
    Thanks for your Help
    Bob
    "Seattle 1996 model 3388" post=821846 wrote:
    [attachment]undefined wrote:
    image2.jpg[/attachment] [attachment]undefined wrote:
    image2.jpg[/attachment]Does anyone know where I could buy this clip ? Its original to my boat and holds the backrest up on the commaned bridge to the fiberglass. Its on the starbird side and the backrest is L shaped. One clip was accientlaly bent and the other was broken when someone was working on my boat. Now the backrest is somewhat loose. Any help would be appreciated, as my screename says its 1996 3388 Bayliner. Not a super technical piece but it fits into the adjacent piece on the back of the cushion.
    Welcome to BOC. Can't answer your question, but I can tell you how to post photos.
    Below the opened posting text window is an 'Attachments' box. Click on that. Then click on 'Add files'. This opens a window to your computer. Select your photos and hit 'Choose'. This brings them into a box below your text. If you want to leave them just as an addition to your post, do nothing. But if you want the photo added into your text, put the cursor where you want the photo and click 'Insert' below the photo you want. Once you are satisfied with your post, select 'Submit'.
    MMSI: 367637220
    HAM: KE7TTR
    TDI tech diver
    Kevin
