Info on my Bravo 3 drive with serial number-gctid821810
    I have got the ID tag from my Mercruiser Bravo 3 outdrive, but i am drawing a blank trying to find a search tool to find out info on it, i.e what year it was made, what type of Bravo drive it is etc.
    Can anyone help, i have attached the ID tag with serial info on,
    Serial: 2a310865
    Ratio: 2.20
    m no: 5441500TR
    Same blank. The tag numbers don't really match. Where is that tag located? Is it possible that the lower unit has been changed to a B3 but upper is B1 or B2?
    It might be worth a phone call to Mercruiser Customer Service.
      Here is my drive, the tag was situated where the 3 bolts hold it on horizontally on the left side, you can just make out the tag joined between the two nuts.
      it does look like a bravo 3 though
        It's definitely a B3 lower, are you wanting to verify the overall drive ratio?
