120 phase in 120/240 50amp-gctid821705
    I understand there are 4 wires: Neutral, ground, 120, and 120.
    are the two 120 wires 180degrees out of phase, similar to
    the two 120 legs of a home electrical panel?
    Novurania 335DL. 30HP. WKRP in cincinnati. Previously: Bayliner 3818 in PNW.
    single phase service... yes similar to
      if you put the VOM black lead onto one of the hot 50a wires,
      and the VOM red lead onto the other hot 50a wire: does the voltage read 240
      or does it read as zero?
        Yes, it is single phase 120/240 service just like your house. The two hots are 180 degrees out of phase. To test that dock is correctly wired volt meter should read 240 hot to hot and 120 either hot to neutral.
        John Rupp
        1989 2455 Ciera Sunbridge
        5.8 OMC Cobra
        1989 3288
        Starshine
        Hino 135
          [color]blue wrote:
          Think in terms of two legs, each @ 120 vac (often referred to as L1 and L2 or Line 1 and Line 2)
          Then you'll have one Neutral ...... and one Earth Ground. [/color]
