3255 Avanti Lever Control-gctid821703
    Hello All,
    I have just purchased an 1989 3255 Avanti, is it possible to change from the installed two control lever to a classic four lever engine control, any help in this matter would be very much appreciated.
    Best Regards
    Tj.
    1989 Avanti 3255
    Twin 5.7 OMC
    Boat Name : UK2
    BYC Lake Simcoe
    Welcome! First, the standard request: please add your boat information and where you live/boat to your signature. It's part of you profile.
    As to changing from two "single levers" to a traditional two lever shifter on one and throttle on the other, it may be relatively easy or next to tearing your hair out. First, are your single levers electric connected to slaves at the engines? In this case you are in for the controls plus cables at, for estimating purposes, $50-60 each. You may be able to sell the electric kit and recover a good share of that cost but running the cables can be a pain. Then there in the mounting hole. Are there places to mount the controls?
    If they are cables, it's probably just a case of connecting the cables to the appropriate levers and adjusting. If this is the case, I may be interested in your "singles".
      Avanti went with single levers because there simply isn't enough room on the dash...
      Do you have enough room?
        Id be interested in seeing this as well. I recently purchased a 1987 Avanti 3255 and there is no way I could mount that set up on my dash. I feel, just by watching everyone elses videos that the separate controls set up would be more practical, but like I said, I just dont see where there would be room.
        1987 Bayliner Avanti 3255
        Twin OMC 5.7L 4V
          Hello JJ,
          I just took my Avanti out of the water (dry dock for the winter) yesterday and my mechanic has said that it could be done obviously at a cost, so we will be looking into that between now and spring, if and when we start i will take progress pics and keep you up to date.
          Chhers
          Tj.
          1989 Avanti 3255
          Twin 5.7 OMC
          Boat Name : UK2
          BYC Lake Simcoe
            This is not my helm but similar this was our thoughts, the only issue would be the control housing length
            1989 Avanti 3255
            Twin 5.7 OMC
            Boat Name : UK2
            BYC Lake Simcoe
              That makes sense! I'm definitely interested in seeing the outcome here! I didn't even consider a dual control setup. I was thinking the four in one. I wonder how the rigging is accomplished with two control beads versus two? :huh:
              Twin OMC 5.7L 4V
                will keep you posted.
                Cheers Tj.
                1989 Avanti 3255
                Twin 5.7 OMC
                Boat Name : UK2
                BYC Lake Simcoe
