Hi Guys, first off want to thank you for taking a look at my post. Today I was out on my boat and long story short out of the whole it really bogged to get on plane, then when finally on plane would only top out at about 3700 to 3900 rpm. The boat first hesitated when it when to take off out of the whole then came back up on power but still bogged out of the hole. I'm a little miffed. I searched our forums for about 30 mins for this issue then just decided to post this instead. After I got off the water today I went and bought new plugs and installed them and also added a bottle of seafoam to the tank. I haven't run it since, but wondering if you have any other thoughts. Should I also replace fuel filter? If I should replace fuel filter can someone point me in the right direction on how to do it? Thanks J.J.!!! I added a pic to show what the plugs looked like after I pulled them out.
Specs, boat is a 2008 185 4.3 L. No mods to it. Prop is factory with 23p.
