The Bayliner Owners Club is a gathering place for Bayliner Owners and prospective owners. No matter what size or model of Bayliner Boat that you have or are contemplating, we have members here who have that same model and would enjoy discussing it in a friendly, welcoming environment.
PLEASE HELP SUPPORT OUR SITE
The Bayliner Owners Club and its Decades of stored boating information is funded by you, the people that visit here. This funding comes from member donations, or through your clicking on advertisements.
Joining the BOC is easy and free.
If you join, you can choose to either contribute and not see any advertising, or you can choose not to contribute, and you will see the same advertising you are seeing right now.
Thanks for visiting the Bayliner Owners Club!!
Please do us a favor by clicking on, then spending a minute visiting our advertisers.
I have a 32' Bayliner Cruiser. The previous owner did not pump out regularly and now I have solid waste solidified in the tank. Any suggestions on removal or on removal of the tank? Does any one know what size tank this boat my use and any help on install would be greatly appreciated.
Wow! I think I'd try to some holding tank enzymes then run a paint stirring tool that is more like an impeller than a a paddle stile. Then agitate, rinse and repeat.
Good luck.
P/C Pete
Edmonds Yacht Club (Commodore 1993) 1988 3818 "GLAUBEN”
Hino EH700 175 Onan MDKD Genset
MMSI 367770440
:sick: :sick: if the tank is strapped down remove the strap and put a large dowel under the middle of the tank. fill the tank 1/4 with water and enzymes as suggested. The dowel will let you rock the tank to loosen the solids hopefully. Pump, rinse and repeat. Do you have an access hatch cut in the floor above the cave? Many of us have done this modification without regret.
"Martini's Law" SOLD
1986 Bayliner 3270, 110 Hino's
Nova Scotia, Canada
You mean I'm not the only guy that happened to? The float on the sender fell off into the holding tank and the previous owner's kid just kept pumping the tank full of crap.
So much that it backed up and solidified all the way up the vent line, the clean out line and towards the head. I don't know how lucky you are but you should consider pulling the tank and inspecting all the hoses that lead to the Y valve, head, cleanout line and the macerator. I'm on inland waters so I threw out the Y valve and macerator.
Chances are as in my case the float fell off and they didn't know it. If its solidified in the tank, the clean out line is plugged too.
56 dollars new sender parts
100 dollars new waste hoses and fittings
and if the vent line is clean you are good to go.
If it were me I'd pull the tank and get it out of the boat for cleaning so there won't be any splash and you can continue to use the boat without the smell.
Dan
Frostbite Falls, Minnesota
Claudia V. III
1988 - 3218
Gas Drives
