Hello Boaters.
I have a 2006 Bayliner 25 (5.0/carbureted/fuel pump) Cruiser.
The engine alarm on the boat is intermittently going on and off at all times during operation. Alarm sometimes sounds at start up and stays on for 5 minutes and sometimes comes on during 4k rpm cruise. I checked the engine and found the oil at the low range, put a quart in which filled it up, restarted and the alarm went away for a little while and then came back on. Gauges are at 175 Temp, Oil at 40-50, Gear Oil full. Engine is hot but not excessive. While alarm is sounding, I have disconnected the oil pressure switch, gear oil switch, and the temp switch, and the alarm continues to sounds. I'm at a loss on what I can do next to nail this one down.
Thanks for the advise.
