I want to install a transducer that I already have. I want to pass the cable (and it's connector) through the transom on the high side above the water line. I found a product that matches what I want, but the hole size is 3/4" and I need just under 1" to pass my connector through. Do you know of a 1" hole option to suit my needs? The cable OD is only 1/4" if not less.
Here is the thru-hull part by SeaChoice
Plan B is to use the above thru-hull solution and then take my transducer cable and cut it. Then splice it back together with solder/heatshrink/spit.
Edit, found this as a better option for plan B. It is IP68 rated and just one hole to drill that is 0.60":
Or, I oversize the gland to a PG21, do not cut my cable, and drill a single hole that is 1.1", but would need a special insert for the very small cable diameter and that's a rather large hole to drill with that degree is precision. I'm sure my hole saws go in 1.4" increments.
Oh, and I found this, but its 5 holes total. However, the cable hole would be exact to my cable (1/4") and the panel mount holes might no go through the hull entirely.
