I just rebuilt 5.8l omc.030 over and upped the cam a little otherwise stock 24' hardtop with cobra drive. I have a 15x16 on the boat it came with but thinking not the best. any recommendations . First post. Thanks
1989 trophy 2459 5.8l recommended prop size and pitch-gctid820867
I live in Santa Cruz Ca
1989 trophy 2459 hardtop with omc 5.8L (5.97l now) fresh and closed cooling system w/ OMC cobra stern 15 Evinrude kicker.
I fish inshore rock, halibut, salmon and tuna within range. Fish Monterey and Half moon bay Calif. Had boat 15 years. Pretty handy.Tags: None
My 5.7 gm (new base engine)is mated to a 5.0 geared cobra on an 89 2160. I currently run a three blade aluminum 15x17. It will redline over engine spec. if I let it. It needs a 19p at least to hook up the 5.7 properly. I'd start there at 15x19 three blade or 15x20p four blade.
I run a 15x17 on mine. WOT is 4600 RPM @ 35kts.
Welcome to BOC. Please click on your name, then 'edit' to fill out your profile. Include your boat size, year and model, and where you live. It would also be great if you included some details about what you plan to use your boat for, and how much boating experience you have. That way we can better tailor fit our answers to your specific situation.
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
That 5.8 has a sweet torque power band doesn't it ?
" WET EVER "
mmsi 338108404
mmsi 338124956
yes it pulls forever and hole shots well and it is fresh .030 over rebuild with a bit more cam. Never had too much time at WOT but would like to troll slower and cruise faster. Prop math eludes me. i know I have to get out this week and WOT a couple runs and come back to you all. Thanks. Not worried about the motor it will perform. I was thinking about a 19 but it may be to much pitch.
I never need to "hammer it" to climb out, it will get on step with just nudging the throttle forward. I don't think I ever run much over 50% throttle, the conditions I run in don't allow for anything over 25 mph.
The last time I recall a WOT pull on flat water trimmed very loose, it was on it's way to 40 mph when pulled out. That was with the 17" SS
Did you by chance change your heads to GT40's ? Center riser manifolds ?
" WET EVER "
mmsi 338108404
mmsi 338124956
The heads are the same had to go to center risers which caused a complete redesign and relocation of heat exchanger to above water pump. What a pain. Also shifted my 2 agm 110# batteries to just inside the cuddy centered to shift 220lbs weight forward and balanced the weight better. Taking it out tomorrow to see how it rides and hope it doesn't bounce so much.
