Reproping 1996 bayliner 2355-gctid399147
    Hi, I have a 1996 bayliner ciera 2355 with a 5.7l engine. I have put on a FAST EFI system, MSD ignition, Eddie Marine header manifolds with ss risers, and a Eldebrock Mid rise intake with the air gap between the oil valley and intake tubes. My boat originaly would only get 38 kph at 3800 rpm MAX. After doing the work I can now get over 6000 rpm, but i set the rev limiter at 4500. I believe that i am under proped. Any suggestions I am going to take the prop off and find out what it is for size tonight.
    And i can only do about 25 - 30 miles on 110 litters of fuel. cruising at 3000rpm just up on plane.
    But any help would be appreciated.
    daren
    the current prop is 14.5" x 15p
