Bayliner 3270 aft anchor winch install?-gctid820504
    Has anyone installed a aft anchorwinch on a 3270 or 3288? Id like to get some ideas/suggestions where people installed their...
    New owner of a 3270, 2xHino 135
    I don't think there is enough meat back there to mount one let alone pull a anchor in.
    Dan
    Frostbite Falls, Minnesota
    Claudia V. III
    1988 - 3218
    Gas Drives
      Look at Carman's docking videos
      He has one.
      Ron
      1989 3218, twin 350 gas motors
      1988 Boston Whaler 13 Super Sport Limited
      2007 Yamaha VX Cruiser
      2012 Yamaha FX Cruiser
        i hawe done it on my boat.
        i did change the fuel tank att the same time, so i got shorter fuel tank, ang ghot more space between the stern and the tank on port side.
        on starboard side you may gott tha space you need.
        What the name off the windless you going to use?
        i ghot picturs how i did it, i tray to fint them later.
        subscribe to my youtube channel
        www.youtube.com/c/MyBoatandMylife
          Havent decided yet which im going to buy. I have an same anchor winch as its in the bow which i got but i dont know if im gonna use it.... Which model do you have? It would be great if you could find the pictures. Och Carman, har f├Âljt och see p├Ñ dina bilder i en svensk forum hur du byggt om din b├Ñt, mest intresserad av ditt bakd├ñcks tsk, den var bra... Sorry for the swedish here in the middle...
            Hi !
            on my boat i got a steern door on starboard side, so i didn't want that anger on starboard side.
            i don't like the winch on the stern, so i look fore som space inside the transroom.
            Ist not Match space between the fueletank and the steernwall.
              My solution..... i newer do anything the easy way :unsure:
              My starboard fuel tank where leaking, and i didn't want to pull the engins. I cut out the old tanks om both side and installed shorter ones how i cud fit whid out pull the engins.
              Whid smaler tanks i haw lots of space to install my Winch and space for my line.
              i ghot 50m line and it is led inside the line to ad whigt to it. The winch is from Engbo. to get it to work well you need at least 0,5m of drop from the winch to botom of the spot where the line drops.
