Fresh water pump surging-gctid820436
    Hey so this year my aater pressure is really low and now the pump is surging on and off while the tap is open.
    How to adjust? Theres not an accumulator on a 2655 right? Seems like theres a screw you turn for pressure or maybe try to bleed air at the screen at pump?
    1993 formula pc 31 twin 454 bravo 2
    1989 2655 cierra 5.7 omc cobra
    2014 "searay" tandom trailer
    Anchor bay clinton river
    Michigan
    Sounds like you have a plugging filter in the line. Start with the mesh strainer before the pump then if you have other in line filters, Chang them out too.
      Got a vent on that tank ?
        Take the tank full cap off and see if the problem goes away. If the problem goes away then it must be the tank vent is clogged.
        Jim McNeely
        Twin 5.7s with Bravo2 drives
        Brighton, Michigan USA
        MMSI # 367393410
          Check the hose connections, the surging sounds like there is air being introduced into the system. Happened to me. My .02
          Brett & Elise, Sammy + Wilson
          New Addition - 2002 Trophy 2002WA FF Optimax 135
          GO HAWKS!
            I don't understand how the system pressurizes if it doesn't have an accumulator tank..
            Thanks i will try these things
            Michigan
              The pump builds pressure to, say, 20psi, then a pressure switch turns the motor off locking the water pressure in the system. Simple so far. Plumbed like that is just fine but the pump will cycle from time to time as pressure weeps off to who knows where. I doesn't bother me, but it does others. The Accumulator acts like a shock absorber because it's filled with pressurized air and maybe a bit of water. They were brought into household codes to prevent "water hammers", surging water slamming into closed valves and fittings causing general mayhem.
                Wouldnt you think when you crack open the filler cap it would lose that pressure? From what I remember it doesnt.. this when I decided i dont need to understand this boat plumbing
                Michigan
                  We had the same problem last year. It turned out to be the little mesh screen right on the outlet of the faucet. Take it off, clean it out and see if things improve. Not much to lose giving it a try and it is a quick and easy job.
                  2014 Double Eagle 176EXL. But we are not done with Bayliner yet…this is just to get us to and from our cottage in the Gulf Islands.
                    Yup... this. I just went through all of this. Started with a new tank vent ... mine was completely plugged. Replaced the pump as my pressure switch wasn't working and a rebuild wasn't much cheaper. Just yesterday replaced my vacuum side strainer which was sucking air into the system at pressure due to a failed seal, and added an accumulator on the pressure side. All is great now. Except water quality, but that's a separate issue
                    Tyson, Ackerley, Sidney & Gene
                    Tsawwassen, BC
                    1996 2858 Ciera Command Bridge - "Island Passport"
                    Mercruiser 7.4L (GEN. V) GM 454 V-8; Engine Serial 0F603347
                    BRAVO III retrofit
                    Home Marina: Tillicum Bay Marina, Sechelt Inlet, BC
                      Did you leave water in the hot water tank? I noticed when i did this the water was so putrid it took multiple flushes to get it out.
                      Michigan
                        When? Over winter? No, I drained it.... then ran RV antifreeze through it. This year I'm adding in a HW heater bypass so I don't have to buy so much antifreeze.
                        I've been doing a bleach sanitise every few weeks this summer... filling the tank up about 1/2 way, adding in a cup or 2 of bleach... running the taps until I can smell bleach... going for a spin to splash things around the tank, then opening all taps and filling/flushing until the bleach smell is mostly gone. This gets rid of the smells for a while... but they come back. I can tell when the screen mesh in my pre-pump strainer starts to get gunked up with green goo that it's time to sanitise again. Annoying, but not sure what the solution is.
                        Anyway, kind of OT for this thread.
                        Tsawwassen, BC
                        BRAVO III retrofit
                          Have you changed out your fill and vent hoses for the tank? I had an issue with mold inside the hoses, so, when I filled the tank I was washing some into the tank either from the fill or vent. I replaced the lines, no more problems, happy Admiral.
                            My vent hose is pretty nasty looking. Not sure about the fill. I considered changing these out, but the fill hose in particular will be a right B*tch to change... access isn't brilliant. If I need to open everything up to get at the tank, might was well change the tank too I suppose...
                            Tsawwassen, BC
                            BRAVO III retrofit
                              If it aint broke dont fix it..
                              It still could be the hot water tank. If there is an easy way to bypass it maybe try that and see if it still is getting nasty. They get soo gross from the heat. I just took mine out, no need for it more room in my bilge
                              Michigan
