Moving away from the dock, forward works perfect. But when I shift it in reverse, it starts to stumble and shudder, even once it is fully in gear. This continues when I pull the throttle back to rev the engine. As I shift it back into neutral, the idle returns to normal.
What might be causing this, and Is this something I can easily adjust? Or should I be leaving it to my OMC mechanic to fix/solve?
