It looks like there's oil spraying from my VP280 tilt motor onto my transom and into my bilge on my 2850 Contessa. The screws on the motor had loosened and when I tightened them (before they loosened again) it appeared to stop the spray. It's a mechanical system that shouldn't have oil in it! Would the original owner have put oil in the system? I've been told the screws seem to be stripped so I'm just having the motor disconnected in case it's activated on its own somehow.
I've got a new rebuilt Mercruiser 383 stroker and my mechanic says the oil in the bilge doesn't seem to be engine oil and that there it wouldn't be drive oil in the bilge.
Just thought I'd ask if there are any other known culprits that would spray oil on the transom (just to port of amidships behind the black cylindrical motor - the motor has a white smear of paint on it in the attached photo).
Thanks!
Thanks!
