I own a 1999 Bayliner Cierra 2655 Merc 5.0 . I recently noticed gear lube in my bildge. i also noticed lube oil on top of the resovoir. I cleaned the entire resovoir with degreaser and filled it halfway. I took the boat for a ride with the engine hatch open and a friend holding the resovoir in his hand. As we drove , we noticed gear oil leaking from the cap on the top of the resovoir. (leaking from the little hole on top of the cap). my question is, does anyone know is this a bad cap? or some kind of blockage in drive forcing fluid out of the top of cap? any suggestions would be greatly appreciated. Thanks
