Both my Starboard and Port Oil Gauges are reading high (Around 80) when I push the throttle, but gauges go back to normal (at around 40) when just at idle. Any ideas why this is happening. I have a 2000 Bayliner Ciera 3055.
Oil Gauges Reading High-gctid819414
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
Welcome aboard !
T in a manual gauge at the sender, leave it there, then you will know exactly what the true psi is.
The OEM pitot tube speedometers are often inaccurate and can become non functional from being clogged up with salt deposits or debris. Look to clear the small hole in the leading edge of the lower unit, it'll be about 5-6" below the cavitation plate.
