No power to ignition. 2010 195BR-gctid819195
    Hey all. Boat was running fine today. Then went to start it again and no beep on the ignition. No turning over. No sound. Nothing. Bilge works. Fan works. Trim works. Battery charged. I fiddled with the battery cables. Nothing.
    Must be a fuse of something. Any idea where I can look? Thanks in advance.
    If it's like my 2007 there is a 15 amp fuse toward the back of the engine. Mine did the same thing. Looked all around for an inline fuse on the ignition and finally found this 15 amp fuse on the engine.
    Now my problem is the 20 amp fuse for the TKS keeps blowing.
    Hope you find the fuse I'm talking about.
      Make sure the control is in neutral wiggle the handle back and forth, bet it's the neutral safety switch.
