Just got HOLODECK back from the shop after hitting a rock and damaging a prop. Anyway, I am tired, been going for 36 hours now. Anyway, I placed her in the slip, hooked up the electric cords and before hooking up the water hose, I decided to top off the water tank. Walked over, took the cap off, stuffed the hose inside and turned on the water. Walked away for 3 minutes and started to smell GASOLINE! OH YES! I stuck the hose inside the port gas tank!!!!!! The tank was full, so who knows how much water went in. There was gas all on the water, which evaporated quickly. BUT NOW I HAVE ABOUT 10 gallons of water in the port tank. Anyone else ever do this dumb a$$ed thing? Will I need to drain the entire tank? Can I get a suction hose down the bottom and try and get only the water? Any additive that will mix with the water?
I am so sick to my stomach over this one. I am going to paint the gas caps red tomorrow and the water fill blue. But that doesn't fix this! Suggestions??
