I currently do not have A/C. Looking at options. I do have twins so a little aft-heavy now. I assume factory install is in the bilge SB side on the shelf. Or is it in the area behind the refrigerator? That would make more sense.
Can anyone show me either an original install or aftermarket? I am trying to determine if it's worth the effort.
Where are the ducts? I would have to run them new.
Control panel?
Water pickup and drain are not an issue.
Wiring source is not an issue.
Control panel?
