Exhaust rider/elbow leak-gctid818494
  • Exhaust rider/elbow leak-gctid818494
    Well I noticed a little steam in the exhaust Sunday so I popped the engine hatch and saw a leak in my riser/elbow. Water dripping out.
    I have closed cooling but since I have a plastic drain plug on the exhaust manifold (and water came out, not coolant when I winterized) I guess I only have s half system?
    So I'll need to buy new exhaust manifolds too?
    Safe to take it apart in the slip or do I need to put it on the trailer?
    Esteban
    Huntington Beach, California
    2018 Element 16
    Esteban
    2018 Element 16
      From bottom to top you have a Manifold, a Spacer/Riser and an Elbow.
      Before you attempt to crack any bolts loose, warm the engine up. This will reduce the likelihood of snapping a bolt off.
      You can finish removing the bolts when things cool back down.
      Post a few photos of the mating surfaces when you have it torn down.
      Volvo Penta Duo Prop Drives
        Crack the nuts when the exhaust is hot?
        Should I drip kroil on before heating up?
        Esteban
        2018 Element 16
          Penitrating oil Is always helpful. Yes it apears you have a part closed system. Personally I'd put it on the trailer before removing the exhaust components because you can
            It never hurts but those are really long bolts and getting the penetrant to the threads is going to be a challenge with the bolts fully tight. I've had consistent success using a socket wrench with a long handle, a bending beam torque wrench works well, with steady pressure to break the bolts loose. I'd break a bolt loose the snug it back up then go to the next bolt.
              Heat is your friend when it comes to this.
              Start the engine and allow the exhaust to warm up......... you have nothing to lose!
                +1 engine warm.
                When you get to the mani remove both end bolts, buy 2 bolts about 2-3 inches longer cut off the heads install the bolts and remove the rest, now slide off the mani on the cut off head bolts, chase all the holes and install the cut off ones on the ends and do the do.
                Post back with the pics.
                  ON TRAILER
                  Something always goes 'not as planned', to be at home with access to tools or equipment always ends up better.
                  Have done manifolds, spacers and risers (elbows) on both my last 2 boats, and went smooth as silk, no stuck bolts, not issues. Just prepare yourself to handle the wight of the manifold when you remove the bolts. Also have a couple of correctly sized studs to put into block temporarily to hold manifold gaskets in place for re-install, or what I did last time is tie them to manifold with thread prior to install and pull thread off (if possible) when couple of bolts have been installed. Not a hard job, just need to be flexible and deal with weight. Hint: I laid a 2x4 across from boat from side to side on top of gunwales, and used some rope to hold the manifolds just below installation level so I could position them then line up bolts. Ain't working alone a joy! Always people ready to ride on boat, but never around when time to work on it!
                    I think I'll get new manifolds, risers, and spacers.
                    Anyone try the aluminum ones?
                    And so far, this 2859 has been a pleasure to work on. Roomy everywhere.
                    Esteban
                    2018 Element 16
                      Esteban
                      2018 Element 16
