Hello all,
I recently purchased the Element E18 with the 115 Mercury 4 stroke. I just replaced the factory Black Max propeller with a 4 Blade Spitfire from Mercury. The factory propeller had the flo torq II hub kit and that is what came with the spitfire. After installation, there is very slight movement of the prop on the shaft. Is this normal? I torqued it to proper specs and all components are installed correctly. I have read that slight movement is normal, but also that is shouldn't move. I haven't taken it out on the water yet, but plan to soon and I will report back on the performance.
[li][/li]
[li][/li]
