Struggle to start this motor every time it sits for more than a week, I know it has electric fuel pump, and believe electric choke, so assume i do not have to advance throttle full to set choke, but this thing is a pain to start cold. I usually turn on key, move throttle to about 1/3 and crank................and crank, and crank, (getting the point). Then if I mess with the throttle any more (pump once), seems like it floods. Then need full open throttle to get air into carb and hopefully finally start.
Any one else with this rig have suggestions.
Miss my old 350 mag injected.....turn key, start!!
