I know it has been discussed a lot and i did my research, however i am still not clear on the best way to achieve this:
I have two battery system in my 2855. Its a standard one, with the 1/2/Both switch and came with two cranking batteries. It works fine.
What I want is to add a large deep cycle battery to run my stereo and amp and possibly fridge. So if it dies it dies, i don't care, i will charge it once back at the dock.
Also, every time i anchor, i don't want to go in the bilge to switch between the batteries as well. Also i like the idea of two cranking batteries, just in case.
Also when i am on the go , it would be nice if it would be charging if i am listening to music.
So i can actually connect fridge, amp and a stereo to it, question is where do i connect the battery to charge when on the go and in the dock since the system is designed for two batteries.
I would really appreciate the advise on it.
