Does anyone have a part number for a 1988-1989 crusader 454 with prestolite points ignition? The coil I have has no numbers on it, just says "no external resistor required".
What coil for 1988 454 Crusader-gctid817817
I converted to Pertronix no points conversion and use a Pertronix 40,000 volt coil.
The conversion is a simple install, then check the timing.
No more points.
Search Pertronix ignition for the conversion.
Thanks for the info, not really looking to convert, just looking for a new coil for my stbd engine
If you have a ballast resister bolted to the top of the engine then you need a coil for the ohms.resistens.that is stated on the ballast resister. If you have no ballast resister then get a coil that needs no resister. If you don't know what a resister looks like it's a white/ cream color ceramic thingy rectangle about 3 inches long.
1989 Avanti 3450 Sunbridge
twin 454's
MV Mar-Y-Sol
Twin chevy 350's inboard
Ben- Jamin
spokane Washington
