It's time, my boat wanders, around enough to irk me into a new steering cable. So where is the OEM length stamped on the steering? I'd rather have it handy and order it in advance than yank and measure.
Is the length stamped on the steering rack or cable someplace-gctid817794
If they are Teleflex/Seastar cables then I believe the cable part number is stamped into the jacket within the first few feet of ONE end of the cable. I had a customer support e-mail from them telling me it will start with a letter then be 5 or 6 digits long then -003- then the cable length in inches.
Hope this helps.
Tyson, Ackerley, Sidney & Gene
Tsawwassen, BC
1996 2858 Ciera Command Bridge - "Island Passport"
Mercruiser 7.4L (GEN. V) GM 454 V-8; Engine Serial 0F603347
BRAVO III retrofit
Home Marina: Tillicum Bay Marina, Sechelt Inlet, BC
I do not use the remove and measure system, it is much easier to get the length from one end of the cable then buy a new cable and tape the new to the old and pull the new cable into place depending if there are clamps holding the cable in the mid section.
It's nice if you can do that, people twist tie to the cable wires they ran.
Ok I went up under the panel and it's a teleflex but no numbers on either end , at least visible!. So it's the measure method. I'd rather order first and install when the day is right so just how is this measured, from where to where. I am replacing the worn rack as well. I can get at all of it to lay a tape on as long as I do a section at a time and mark it. Sojust how accurate does this have to be?
Sorry, I misread your post...I was referring to shift/throttle cables...Your profile (what boat you have) is not filled out but you can find the cable specs from the bayliner parts catalog for your model...that's where I found mine. Hope this helps...
Brad & Michelle
Jet & Maverick
1993 3688 "the Kraken"
Hino W06 250HP
14' Avon RIB, 50hp Tohatsu
Moored at Shelter Bay
LaConner, WA
One FOOT too long... you get to carry around more cable and you'll never feel the difference. I measured mine and then bought a foot longer for good measure. I bought the entire helm and it was an easy change. Hardest part was getting the wheel off.
