Last Wednesday: Everything was working fine when we left the dock, but when I returned, the OD wouldn't raise. I wiggled the throttle, etc. Everything I tried, failed. Called my OMC mechanic, and he suggested I check the fuses. I didn't know which of the two it was, so I checked both and they were fine. I tried the trim and it worked. I thought it was just a loose connection, and that I'd fixed it. Mechanic also said the problem is likely with the connections on the engine, and not with the 'shift lever'.
This morning: Same thing happened. Wiggled the shifter while pressing the up button, and nothing. Did the fuse thing, and it still didn't work. I finally shorted across the 'raise solenoid' (#4 in the photo) and the OD came up. Suggestions what the problem could be? Might it be the solenoid? If so, where might I find another one?
Also, what are #1 and #2 in the photo?
Kevin
Kevin
