Hi all, I am replacing my points distributor on my 86 OMC Cobra 5.0l with an HEI marine version and need to feed it 12v power eliminating the resistor wire. What I see on the boat matches up with what I see on the wiring diagram with one purple and black wire and one purple red wire going to the + side coil. From searching I've found a couple different views and I'm a little confused. Is the purple/red wire the resistance wire? It feeds back to a splice and then the alternator. Also, if I simply eliminate that wire, meaning connect to the alternator wire pre-splice will that suffice to feed 12v direct to the distributor? I am assuming I will need both that wire and the purple/black wire that goes back to the starter to feed power depending on starting/running. ESA system has been eliminated and wired like a merc, I am hoping that will work on an hei distributor as well but haven't gotten there.
Thanks in advance.
Thanks in advance.
