i have a 1995 2452,i am in the process of removing the tank.does anybody know if it is bolted in the back or straped in.i removed the engine but the tank doesnt move much,it seems my next step is to put a winch on it
2452 fuel tank-gctid398702
I just put a new tank in my 2555. Mine had 2X4's glassed across the top from side to side and foamed in around the sides. No other mounts or restraints. I used a saws all along the sides then used a wonder bar to pry until there was enough room to get a 2X4 under neath the tank and it popped right up.
Ted G
The Great PNW
86 2850 Contessa SB
Designers Edition
Mercury 350 Mag
290 Volvo DP
