I am looking at picking up a donor 1985 Cierra 2450 Command Bridge to swap the engine/out drive over to my Trophy in order to up the power a bit from the measly 4 cylinder running gear. Is this engine going to be a handful?
I know propping the engine will take some experimenting, plan is to start with the factory 1985 Cierra prop and go from there to end up with a SS prop for longevity/efficiency. I believe all of the linkages should mate up properly (I haven't picked up the Command Bridge yet so I don't know what drive is on it) but I believe most of the AQ series engines share the same transom shield (correct?).
Thank you, have a great day.
