I have an 89' 2050 Arriva with 5.0 Mercruiser, the fin on the trim tab anode is broken off, and I was told by a repair guy to not worry about it (I filed it off flush so no sharp edges), what exactly does the tab help with, and should I replace it?
Only issue I have with the boat is that it tends to get "tippy" when loaded close to maximum or towing heavy tubes, etc. When turning in these situations (worse turning left), the boat feels like it is riding really high in the water and will actually just tip over, even at 20-30 mph towing/cruising speeds. Is this related to the trim tab anode, or something completely different?
