2655 ciera seen me coming-gctid817181
    90 2655 ciera well don't know where to start, bought ciera from local supposably reputable dealer/ broker after weeks/ months of cleaning repairing put in water,got to end of channel,started smoking towed in bad impeller had repaired also Gimbel bearing .put in water didn't over heat but no power spit sputter got to dock called mechanic ,carb rebuild ok boat sat for a few years,mechanic said automobile carburetor illegal,oh by the way distributor if from automobile illegal. l replaced both (ouch). Took boat out after all done complete tune up oil filter, top to bottom fresh everything took boat out start fine at dock no problems. Took out bogging out no power,SMOKE, OPEN HATCH oil in bilge with water more than I left dock with, shut down towed in No I didn't have surveyed my first mistake any idea on where oil is from? Where to start?[map type=HYBRID zoom=2][/map]
    Was it winterized? Also if you had water in the oil oil filters can corrode from the inside out and get pin holes and blow oil out. If it wasn't winterized properly well then you could have a cracked block or heads.
    1989 Avanti 3450 Sunbridge
    twin 454's
    MV Mar-Y-Sol
    Twin chevy 350's inboard
    Ben- Jamin
    spokane Washington
      "Monkeyman" post=817181 wrote:
      90 2655 ciera well don't know where to start, bought ciera from local supposably reputable dealer/ broker after weeks/ months of cleaning repairing put in water,got to end of channel,started smoking towed in bad impeller had repaired also Gimbel bearing .put in water didn't over heat but no power spit sputter got to dock called mechanic ,carb rebuild ok boat sat for a few years,mechanic said automobile carburetor illegal,oh by the way distributor if from automobile illegal. l replaced both (ouch). Took boat out after all done complete tune up oil filter, top to bottom fresh everything took boat out start fine at dock no problems. Took out bogging out no power,SMOKE, OPEN HATCH oil in bilge with water more than I left dock with, shut down towed in No I didn't have surveyed my first mistake any idea on where oil is from? Where to start?[map type]HYBRID zoom=2 wrote:
      [/map]
      I'd start with proper grammar, because I can barely make out what you are saying.
      Next, I would do a compression test on the engine to determine health.
      Matt Train
      BOC Site Team
      Chicagoland, IL
        i understand him ... he caught a royal howanagotchi.
          Well, you ARE from Jooyyseee.
          :P
          Matt Train
          BOC Site Team
          Chicagoland, IL
