The closer I look at things, the more discouraged I get. I am getting ready to replace the water neck fitting (aka hose connector) on my Penta 280 outdrive, and I was just looking at one of the pictures I took and noticed a crack in the suspension fork. See the picture below. Looks like it's cracked all the way through, though I dont have the boat here to check the inside. I am wondering how bad this is to drive with it cracked like this.. Im also wondering if as soon as I pull out the bolts holding the water neck fitting, the suspension fork is going to give way and the entire outdrive is going to try to drop... Does anyone have any idea how much stress is actually on that part, and what the possibilities are if I leave it? I assume to change it I have to pull the whole outdrive, but I havent really looked...
