2650 Explorer update II-gctid816749
    Since I last posted in February about my rotten floor I have completed a number of task:
    1) Remove paint on hull down to gelcoat
    2) Replace freshwater pump, new pex lines to new water heater and new faucet in galley
    3) Replace electric service(AC) pnl and install voltmeters to each battery
    4) Replace engine soundproofing
    5) Remove and replace galley top, install new propane system and new two burner stove
    6) Re foam and recover cabin upholstery with sunbrella
    7) Re do Helm to allow use of Raymarine e-80
    Original helm photo
    re do of helm
    New upholstery colors
    Water heater, heated by engine
    Battery charger and new DC busses
    New AC panel and DC voltmeters
    2650 Bayliner Explorer Express , 1980 model , single diesel; Isuza 4BDI, 280 outdrive,
    previous boats,
    Sea Ray 31, Tolly 48
    Great loop completed 2006
    10 year live aboard
    retired to land 2015
    rmitch
    Nice job! A+!
    MMSI: 367637220
    HAM: KE7TTR
    TDI tech diver
    Kevin
      Wow!
      Yellowknife, NT. Canada
      2002 cierra 3055
      twin 350 mags mpi FWC w/B2
        Great progress and fine workmanship.
          Moved the boat out of the shop on to the trailer and painted the hull "Fighting Lady Yellow". Ran the engine for the first time in seven years with some hints from this forum using the muff system and plugging the drain hole below the water intake. Got the engine up to temp (180) and found a couple of bad hoses. Replaced a number of hoses, had Billings radiator repair the surge tank, put the coolant system back together and ran again, all is good. Plan to launch in Yellowtail reservoir (on the Montana/Wyoming border) this week. Attached a couple of pictures, she is named "Far West", after a famous Steamboat from the 1870's in Montana, best known for her trip from the Bighorn River to Mandan N Dakota with the wounded from Little Big Horn battle including the wounded horse "Comanche" .
          previous boats,
          10 year live aboard
          rmitch
            Mitch you have accomplished a fine restoration, like the hull color, good luck on the launch.
