Hello Everyone,
I have a loud "rubbing/rumbling like" noise coming from my Starboard engine when going above 2000 RPMs. I can hear the outdrive enage in gear but as soon as I go above 2000 rpm I hear this noise. If I go back down a little it stops but I cant go above 2000 rpms therefore I'm crawling on the SB side. Port is perfectly fine and both engines are completely fine. I am guessing a bad bearing somewhere, maybe the gimbal bearing? Could the lower gears be messed up? OH on land with muffs, it shifted fine and got upto high rpms but this is all happening under load of course. I can try to capture a video later this week. Any help, knowledge, or expertise would be greatly appreciated!
